Browse Forums Landscape & Garden Design 1 Jan 21, 2020 10:53 am Unfortunately in that crazy Sydney storm last night I wasn’t home to even try to protect some of my plants. The hardest hit (to both the plants and my heart) were my giant elephant ears that were the backdrop to my kitchen splash. They have been in for about 8 months and had some leaves that were almost 1m long! The plant seems to have started only sprouting small leaves as of the last month, almost like it knows that’s all it has room for! I’m wondering first of all whether these plants are too damaged to recover, and secondly whether I should be removing some of the damaged leaves. On one plant literally every leaf is smashed and I’m worried about the plants retaining nutrients and having enough surface area to get sunlight. Appreciate your help. Before Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Plants and hail damage 2Jan 24, 2020 2:08 pm Just prune the damaged stalks down to main stalk leaving about 1-2cms space from the 'trunk'. Use a sharp flat blade kitchen knife if the tuber is thick, just to make sure you get a clean cut. Minimise the surface area on the stalk ( cut perpendicular ) as they lose moisture for a while due to the cut. Dose with seasol and molasses before pruning. Re: Plants and hail damage 3Jan 25, 2020 12:44 pm SteveMc Just prune the damaged stalks down to main stalk leaving about 1-2cms space from the 'trunk'. Use a sharp flat blade kitchen knife if the tuber is thick, just to make sure you get a clean cut. Minimise the surface area on the stalk ( cut perpendicular ) as they lose moisture for a while due to the cut. Dose with seasol and molasses before pruning. M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 I thought this would be a popular question but I haven't been able to find any similar posts. Perhaps I'm wording my searches wrong? When you have car insurance and the… 0 6985 there was an event. The question is whether the builder had the insurance and whether the event was covered. The workmanship is a separate conversation. 10 24128 DIY, Home Maintenance & Repair The workmanship is lifetime guarantee by "the insurer", not the builder. They will of course ask the initial builder to rectify and if they don't they will appoint… 7 5895 |
