Browse Forums Landscape & Garden Design Re: Which tool 2Jan 15, 2020 5:10 pm I assume you mean the finish on the concrete. You need a concrete bullnose edging tool. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Which tool 3Jan 15, 2020 5:10 pm I see that you are in Vic. Is it a new home, are you on highly reactive soil and will the paving be the slab's perimeter? If so, then you really need a french drain along that edge to prevent the run off from hydraulicing the path and possibly causing slab issues. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 8205 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12829 Which chrome tapwares is a good affordable brand with a good warranty in Myhomeware shop Sydney. I visited the shop and they… 0 2375 |
