Browse Forums Landscape & Garden Design 1 Jan 30, 2017 4:29 pm I've planted 2 advanced standard Crepe Myrtle Sioux trees in my front garden. They've been in since November, seem to be doing well enough, as there is plenty of new growth and they are blooming now. Now, my question is none of the new growth is on the main trunk. I have a concern that the central trunk won't fill in as it's pretty sparse at the moment. It is still relatively young so time might be all it needs but I don't know if in promoting that central leader whether knocking off any other branches means the tree will stop produces new growth on it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Crepe Myrtle Advice 2Mar 01, 2017 11:56 am I have a number of crepe myrtles. each variety different. zuni seems to grow multi branched, Tuscarora seems to be single stemmed like yours. looking at the pictures at Flemings and ellenby tree farm it would depend on the look you want. Either upright vase looking or take out the central leader to get it to multibranch at a certain height. All I know for sure is you should deadhead them as they flower on new growth. Re: Crepe Myrtle Advice 3Mar 09, 2017 1:31 am It will be fine. You want the lower stuff to get going. I'd bet that top branch snaps at some point in the future if the lower branches don't do some growing. It will take time and form in it's own way. Early days Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17470 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13832 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6900 |
