Browse Forums Landscape & Garden Design 1 Sep 04, 2013 3:27 pm Hi. We have a stormwater pit at the back corner of our property. I would like to raise it to the same height of the existing retaining wall (about 500mm). I would then like to fill the backyard in so its more level. Currently the section where the pit is about 500mm lower than the rest of the backyard. Ive spoken to council and they have said its a private asset so its up to my neighbours and i to agree on any changes. Is this easy to raise? Or should i build a retaining wall around it and fill that way? Re: What can I do with this stormwater pit? 2Sep 04, 2013 4:51 pm It's not to difficult to raise. but depending on the regulations in your state you may need to get a plumber to make the alterations. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: What can I do with this stormwater pit? 4Sep 06, 2013 10:06 pm We had this issue. Our landscaper raised ours by 600mm. You can by pre fab concrete that go over the hole and stack on top of each other. No issue for it to get done. McKeachies Run, Aberglasslyn Deposit paid 11th April Land registered 6th June Land settled 20th June Colour selections and contract signed 5th August Commencement letter received 26th September Re: What can I do with this stormwater pit? 7Sep 12, 2013 10:52 pm Pretty sure our landscaper got it from local landscape supplier. Our landscaper got make of the existing one and ordered extension bits in same manufacturer. McKeachies Run, Aberglasslyn Deposit paid 11th April Land registered 6th June Land settled 20th June Colour selections and contract signed 5th August Commencement letter received 26th September Re: What can I do with this stormwater pit? 9Sep 16, 2013 11:05 am RichA - call your local water authority, you will probably find that they will come out and do it for you for free. I had ours raised 600mm not quite 3 years ago by Sydney water for no cost, they have a group that they use for repairs etc and this was just another job for them - done in around an hour, they just fitted a couple of pre-fab collars ontop of the pit and moved the lid up, then I just filled in around it with soil to bring it up to the new level of the backyard. Re: What can I do with this stormwater pit? 10Sep 16, 2013 2:11 pm To me that looks like a sewer pit, are you sure it is storm water? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What can I do with this stormwater pit? 11Sep 17, 2013 10:50 am Yep, im sure its a stormwater pit. I also have a sewer pit which was raised by sydney water for free last week. I had a plumber come out and look at the stormwater pit and he said they could get a concrete riser (from ROCLAR) for it but it would weigh around 400kg and they would have to crane it into the backyard. Too costly. We will retain around it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: What can I do with this stormwater pit? 12Dec 23, 2019 2:34 pm same issue here in sydney, my Stormwater pit below my slab level 500 mm. Landscaper said just build wooden box of Treated wood around Pit. you cannot raise as per regulation. should be at ground level. confuse guide please. Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10871 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 5638 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 9051 |
