Browse Forums Landscape & Garden Design 1 Apr 02, 2024 8:55 am Hi Brainstrust, I had a go at creating my own irrigation plan, keen to get some feedback. It will be run from one 750-800W pump, off 2* 5000L rain tanks. Each zone will be run at seprate times at night using a controller and solenoids. Keen to get feedback on: How i have seprated the zones The use of pipes (19mm and 13mm) - should they be bigger? The 13mm will feed 4mm drippers and mini sprayers Anything I have missed How many minutes should each zone run at night in summer. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you in advance! Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20412 As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 18343 |
