Browse Forums Landscape & Garden Design 1 Jan 18, 2024 3:03 pm I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. However, the last hole seems to have some wet, soft clay at the bottom. How should I approach this? Keep digging down? Drop some aggregate in? Or just put the concrete in? yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7452 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10461 there is a standard besser block wall pdf somewhere online with footing sizes, also have a look at dincel. 1 3130 |
