Browse Forums Landscape & Garden Design 1 Jan 18, 2024 3:03 pm I've dug some footings to embed a post anchor into. My holes are around 450mm deep which I'll put a 200mm stirrup into. The bottom of these holes seem firm enough. However, the last hole seems to have some wet, soft clay at the bottom. How should I approach this? Keep digging down? Drop some aggregate in? Or just put the concrete in? PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10566 there is a standard besser block wall pdf somewhere online with footing sizes, also have a look at dincel. 1 3239 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 21755 |
