Browse Forums Landscape & Garden Design 1 Oct 13, 2023 12:11 pm Hi there, I'm installing a 20kL round rain water tank next week and would like to know whether the position of the inlet and outlet need to be 180 degrees from each other? Or can they be in the same position? I vaguely remember reading it's good to have these positioned at opposite sides of the tank, but I could be wrong. For context, the rain water will come from a house roof using a wet system, but will only be used to irrigate fruit trees and veggies (potentially plumbed to a laundry). Thanks in advance Re: Location of RWT inlet and outlet 2Oct 13, 2023 4:42 pm It is best not to have water falling into the tank from a position where it would stir up the sediment layer near the outlet that supplies the pump if the tank's water level is low. It is also best to have the inlet basket mesh within arm's reach of the overflow pipe so that the overflow outlet's mesh can cleaned. The mesh however can be removed if the vertical overflow pipe is fitted with an Air Gap that has easily removable mesh for servicing. Removing the mesh from the outlet also increases the overflow outlet's discharge capacity. https://www.bunnings.com.au/rain-harves ... p_p4813647 Water settles in stratified layers with the highest density, lowest oxygen layers found at the bottom in the anaerobic zone. Make sure that the outlet that supplies the pump is 100mm above the bottom of the tank at the valve's lowest point. Best practice will have a floating intake filter fitted that draws the best quality water from 200-300mm below the water surface. If one is fitted, then the outlet valve can be fitted at the bottom of the tank. It is also best practice to connect a flexible UV stabilised hose between the tank's outlet and the pump but use a nut and tail at the tank so that the hose can be easily removed if ever needed. Also have a straight length of suction hose that respects a minimum 8 internal diameters connected to the pump's suction port. Also be wary of using Blue Stripe poly pipe because its nominal diameter is measured as an external diameter. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. ask the surveyor for clarification would be the logical approach 1 20429 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10891 |
