Browse Forums Landscape & Garden Design 1 Aug 11, 2023 11:47 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right will require a 1 meter high retaining walls so it looks like I need a DA. Which one is more cost effective? If I go for full excavation, it might be: - Too costly since my estimate is around 75 cubic meters of dirt to be removed - More areas with high (> 600mm) retaining walls which will require engineer to certify If I go for semi-excavation, then - I have to build retaining walls within the backyard - Can use some of the excavation dirt to fill the front yard Any feedback is much appreciated. Thanks. Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 2549 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 225416 Landscape Design Parramatta We have been doing a large amount of landscape design work in Sydney… 0 3 |
