Browse Forums Landscape & Garden Design 1 Oct 17, 2022 2:03 pm Hi, I built a garden bed in my backyard, and I’m now a bit worried that the timber is too close to the home. Hopefully people here can help I used treated sleepers from Bunnings, with a layer of in-ground timber protector painted on (added some pictures) The garden bed is only for succulents, so the area won’t get watered much (maybe once a month). The soil also doesn’t reach the bricks/mortar. I will be renting the home out eventually, and won’t be able to look after the timber. I’m wondering when the timber eventually breaks down, could it attract termites, and will this be a problem since it’s close to the home? Thanks heaps! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Garden bed too close to home? 2Oct 17, 2022 3:09 pm the bigger issues is having a garden bed against your home. Generally (and in most cases) you want consistent levels of moisture around your house envelope and you definitely don't want to be introducing more water around your footings. Termites love moisture too. As to whether its a termite risk depends on a lot of variables that may not eventuate, but watering a garden bed up against your home will most likely cause you issues down the line. DO you happen to know what type of soil (and the rating) you're on? Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Garden bed too close to home? 3Oct 18, 2022 7:07 am Thanks for the info! I'm not too sure about the soil type we have. I don't imagine we would be watering the garden bed often, they're mostly succulents I'm considering replacing the wood with something else. Re: Garden bed too close to home? 4Oct 18, 2022 8:20 am ctrl Thanks for the info! I'm not too sure about the soil type we have. I don't imagine we would be watering the garden bed often, they're mostly succulents I'm considering replacing the wood with something else. Your soil type would be inthe geotech report that you paid for that was commissioned prior to building. You either have it in your documents, or could obtain it from the builder. Either way, garden beds next to houses are a problem waiting to happen. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Garden bed too close to home? 5Oct 18, 2022 9:09 am ctrl I don't imagine we would be watering the garden bed often, they're mostly succulents. Wind blown rain hitting a wall provides a lot of water to a narrow garden bed. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8446 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5729 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2836 |
