Browse Forums Landscape & Garden Design 1 Sep 27, 2022 3:16 pm Good day, This is in Adelaide, SA. I have had a pool installed and the no climb zone safety requirement is confusing me. The pump station is against a 1.8m high boundary fence inside the pool area. Reading the information below from the SPASA website I am wondering if a fillet at the top of the fence will make this complaint or I need to put an enclosure around the pump station. **** Climbable objects or surfaces should not encroach on the 900mm non climbable zone on the inside of Boundary Fences (1.8m). If a Horizontal Surface is located within the NCZ then a fillet is an acceptable solution which would rectify the problem **** For the water tank, is this considered a climbing risk? Do I need to put up a screen. Note, all this is inside the pool area protected by a compliant fence. Photos to show areas in question. Thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yes it had a house on it. But Melbourne water only wanted something the original size of the existing house. We managed to fit a 45sq house on. 10 34376 Hi Everyone, One of my favourite parts of a build is when the temporary fence comes down and the home begins to reveal itself. It also means we are on the home straight… 103 372437 First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 17426 |
