Browse Forums Landscape & Garden Design 1 May 06, 2022 7:56 pm I need to run drainage (150mm PVC pipe) from my backyard to the front. It needs to run either under about 50m of concrete driveway that will be laid on top of it, or in a 500mm wide space between the fence and driveway, where I want to plant some small hedges. Am I causing future problems if I run it under the driveway? Or should I run it next to the fence line? Perhaps small trees may have a chance of damaging the pipe in the long term? Would under the drive be better, knowing that I'd never be able to access it again? Thanks. Running drainage under length of driveway 2May 06, 2022 9:17 pm under the concrete unless you need to access it, A driveway can be saw cut if needed. If it was under the hedge it would need to be deeper. I’m not a plumber though, so wait for some other opinions. Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20748 2 6497 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 5129 |
