Browse Forums Landscape & Garden Design 1 Oct 18, 2021 5:52 am I'm trying to work out the sequence of events for a piece of landscaping i'm DYI. I've built a retaining wall to level out the soil between us and the neighbours who's slab is about 400mm higher. What we want to do now is scrape the soil to ultimately replace it with better growing soil (currently crap clay and backfill). Though we also want to put a french drain in to take the surface water away. So my question is what order? If we scrape it first, then build the drain, will the drain be too deep? Or scrape, then bring in the soil, then the drain? It might be much of muchness but maybe there's something I'm not thinking of. Many thanks. Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8829 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4709 Agreed. I just found out today the certifier has not given the final sign off. 2 4239 |
