Browse Forums Landscape & Garden Design 1 Sep 10, 2021 4:01 pm concreter refused to fix uneven font concrete !
I just paid him, thought it looks alright. Then my fencer came and tried to set up the racking for sliding gate, it is not level! It has 100mm difference. Now the concreter said nothing wrong and no need to fix, he should know it need to be leveled as the fencer did tell him on the phone prior to start. That's just bad and not gonna go with this concreter anymore! What else I could do now ? Re: concreter refused to fix uneven font concrete 2Sep 10, 2021 10:43 pm Unfortunately your photo doesn't show anything. All external concrete has to have fall and depending on levels it's pretty standard. Cross fall isn't so good but even that can't be helped at times. Usually the gate track is installed before the concrete is poured and the concreter then works to that level. For something as critical as sliding gate tracks it's always a good idea to have a site meeting with the concreter and gate company so everyone is aware of what can and can't be done. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: concreter refused to fix uneven font concrete 3Sep 11, 2021 10:29 am Unsatisfactory result is not always bad workmanship but often bad, vague or missing instruction set and lack of communication supervision and checking. You are the builder and the contractor works for you Who has given drawings and specification to the contractor, who has instructed and checked levels before concreting? Get the gist? Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: concreter refused to fix uneven font concrete 4Sep 12, 2021 9:57 am mmbl concreter refused to fix uneven font concrete ! I just paid him, thought it looks alright. Then my fencer came and tried to set up the racking for sliding gate, it is not level! It has 100mm difference. Now the concreter said nothing wrong and no need to fix, he should know it need to be leveled as the fencer did tell him on the phone prior to start. That's just bad and not gonna go with this concreter anymore! What else I could do now ? How was the gate going to slide without the rails being installed prior to the concrete being poured? Re: concreter refused to fix uneven font concrete 5Sep 12, 2021 10:31 am I have seen domestic sliding gates with surface fixed rails to concrete. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 12218 I hope this help you newhome_24, AS3958.1 is the Ceramic Tile Installation Standard. It specifies the tolerances for the installation of tiles. The tile supplier is… 1 7798 I don't think you're getting a response because you are not quite clear on what the issue is. yep, the site is not level, no site is! but are you just building a garage?… 1 2928 |
