Browse Forums Landscape & Garden Design 1 Aug 19, 2021 8:42 am Hi all I've got 3 levels of plants totalling approx 7ft that I want to add some drip line irrigation to. The tap is at the bottom so I was curious how someone with some experience might tackle this. I was considering running a line to the top and add a pressure reg if needed then run all the drip lines down from there. Fortunately the tap has quite a high flow rate. Thanks John Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 8371 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20754 Hi Brainstrust, I had a go at creating my own irrigation plan, keen to get some feedback. It will be run from one 750-800W pump, off 2* 5000L rain tanks. Each zone… 0 23258 |
