Browse Forums Landscape & Garden Design Re: Need help with west facing wall. 4Feb 22, 2021 8:55 am ligongl How about https://www.smartstonesystems.com/fibro ... t-cladding ? These are thick XPS foams with a thin layer of stone veneer at the face side. The other side can be clamped straight into the brick wall and the gap between the panels are filled with adhesive.
Hope this would give you some alternative ideas, good luck and all the best! Cheers LG Only just noticed your reply. Thanks very much for the info and link. I will do some research. It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 20692 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 19097 Help!! I’m meant to start building soon and have only really just learnt about orientation. Im reading so much that no grass will grow on the heavily shaded south… 0 1278 |
