Browse Forums DIY, Home Maintenance & Repair 1 Jul 09, 2020 5:31 pm Hi all, first time poster. Looking for some advice regarding chips appearing in the concrete of my garage. As per the pictures you can seen waffle foam just beneath the surface. Is this to be expected? Can something be done to fix the issues? Is this something covered by builders warranty? Appreciate the help. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Garage chips - Waffle Foam showing 2Jul 09, 2020 6:48 pm It all depends on what we are seeing. If it's a bit of the styrofoam that has broken off during the installation of the pods and then when the concrete has been poured it's floated up but been troweled in its no big deal. On the other hand if what you can see is actually part of an entire pod that has lifted or has no cover over it then it's a big problem. Try digging the foam out. If it's just a small bit encased in concrete then it's no big deal and can be patched. If you stick a screwdriver into and it keeps pushing in like you have actually got a whole pod at the surface then you have a big issue and I'd be getting it inspected. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Garage chips - Waffle Foam showing 3Jul 09, 2020 7:33 pm chippy It all depends on what we are seeing. If it's a bit of the styrofoam that has broken off during the installation of the pods and then when the concrete has been poured it's floated up but been troweled in its no big deal. On the other hand if what you can see is actually part of an entire pod that has lifted or has no cover over it then it's a big problem. Try digging the foam out. If it's just a small bit encased in concrete then it's no big deal and can be patched. If you stick a screwdriver into and it keeps pushing in like you have actually got a whole pod at the surface then you have a big issue and I'd be getting it inspected. Thanks heaps, really appreciate the advice. Re: Garage chips - Waffle Foam showing 5Jul 13, 2020 10:44 pm Your engineering plans will have the details, but yes typical slab thickness would be 85-100mm. So the foam was more than just a bit of a chip that could be dug out? Did it seem like it was the top of a pod? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Garage chips - Waffle Foam showing 6Jul 15, 2020 10:24 pm chippy Your engineering plans will have the details, but yes typical slab thickness would be 85-100mm. So the foam was more than just a bit of a chip that could be dug out? Did it seem like it was the top of a pod? Builders concreter attended today and investigated the issue. He dug the foam out with wire and both chips were foam the had broken off and floated to the surface. I verified this. Thank god. Thanks again. Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4430 There is nothing in the various codes and standards that puts this requirement on the builder to do. I think that is what you are asking. Don't waste time trying to get… 5 2916 The Soil classification has little to do with piers. The purpose of the classing of the soil is to identify the clay content and the "average expected range of movement… 2 10223 |
