Browse Forums DIY, Home Maintenance & Repair 1 Mar 17, 2020 4:24 pm Hi guys. Any advice GREATLY appreciated.I have a 2 storey 1970s townhouse. It's one of two, attached by a concrete block wall. It had a roof replaced (cathedral ceiling) and since then cracks (gaps?) have appeared between the ceiling and wall seam. Just here and there, not everywhere. Also a gap between the concrete block and wooden trim of the drywall down the length of the house in one corner. This has led me to notice that the upper floor/lower ceiling in that corner isn't straight! You can see in the photos that the cinder block is higher in the corner! All the window frames, doors and the rest of the walls/ floor in the two rooms are level. I have looked under the house at the foundation and can't see anything scary. Could the house have been built like this? Or has something occurred? I can't see any cracks in the cinder block wall. And any advice regarding the gaps that have appeared? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 4 14879 I hope this help you newhome_24, AS3958.1 is the Ceramic Tile Installation Standard. It specifies the tolerances for the installation of tiles. The tile supplier is… 1 7733 I don't think you're getting a response because you are not quite clear on what the issue is. yep, the site is not level, no site is! but are you just building a garage?… 1 2883 |
