Browse Forums DIY, Home Maintenance & Repair Re: How do I remove this plant in between the walls? 2Feb 11, 2020 2:21 pm It's really hard to see from the photo - how far away is it, and what kind of plant is it? You might be able to poison it with zero or similar - use a length of pipe (or pvc conduit or similar) to reach the leaves and very slowly and carefully pour some poison down the pipe? Make sure you do this when there is no rain forecast, and wear gloves etc. and wash up really well afterwards. Re: How do I remove this plant in between the walls? 3Feb 12, 2020 7:30 pm kriss It's really hard to see from the photo - how far away is it, and what kind of plant is it? You might be able to poison it with zero or similar - use a length of pipe (or pvc conduit or similar) to reach the leaves and very slowly and carefully pour some poison down the pipe? Make sure you do this when there is no rain forecast, and wear gloves etc. and wash up really well afterwards. Is this much better? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6572 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12688 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7511 |
