Browse Forums DIY, Home Maintenance & Repair 1 Sep 17, 2019 6:17 pm Hi Just laid a concrete garden shed slab 3 days ago. We obviously didnt push enough concrete under the rebated edge 50mm wide x 25mm deep. Any ideas on how to fix? If I mix up some mortar mix and try to smooth it out will it bond to the existing? As the shed sits on the rebated edge it needs to be smooth. Slab is 2.46m x 2.46m and the shed is 2.36mx2.36m. Rear sideWorked but some holesLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Left hand sideSeems to have worked but back corner didntLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front left hand cornerLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front right hand corner Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 1237 Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 13165 |
