Browse Forums DIY, Home Maintenance & Repair 1 Jul 05, 2019 2:30 pm hey guys, not sure if this should be in here or in windows and doors section I am wanting to convert the below window to a door. our home is on bearers and joist and is bricked on the outside. the window is roughly a full sized door. so i could get custom door frame and door made up. the bricks on the outside come up to the same height as the bottom of the window frame so they will need to be cut down. then put a threshold/subsill type door frame in. with the framing, is there any differences in studs and noggins etc when comparing windows to doors. and would i need to put in more framing? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: converting a window to a door 2Jul 05, 2019 6:58 pm blakewotton with the framing, is there any differences in studs and noggins etc when comparing windows to doors. and would i need to put in more framing? I don’t believe so. We once had a large window set converted to a bifold door set, and they didn’t change anything other than lower the threshold, slot in the new doors and cover the gap with new architrave. Re: converting a window to a door 3Jul 08, 2019 9:22 pm simple! haha. trying to find info and do a bit of research, but everything is involving French doors. If I hire a contractor to convert a window to a sliding door will I need to show them Council approval paperwork? That is, if I want to take a risk of carrying out the… 0 15321 start from at least $20,000 just for fixtures and finishes and then add on for moving plumbing and extra for a concrete floored house last new bathroom we installed in a… 1 19940 I have been looking into getting quotes for a reno I am doing shortly. I have been looking at Trend and Wideline for both windows and doors. I did enquire with Vista but… 0 6497 |
