Browse Forums DIY, Home Maintenance & Repair 1 Mar 29, 2019 10:26 pm We are going to do some besser block entry walls with some time slats in between. Where we live does get a lot of movement in the ground. My question is what can we do to make sure the walls are strong and don't move? This will be our first time doing it. Thank you there is a standard besser block wall pdf somewhere online with footing sizes, also have a look at dincel. 1 3275 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 12401 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11456 |
