Browse Forums DIY, Home Maintenance & Repair 1 Apr 22, 2018 7:12 pm Without knowing what timber this is, is this bench seat saveable? and would i need to sand it down before any kind of treatment ? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Renovating garden bench 2May 05, 2018 4:27 pm i repaired one recently & i would say it depends on what tools you have. We found one that looked as through it needed some slats replaced, but turned out nothing like that. The back side had dry rot, so i had to take out the router and make a new back section. I was pretty time consuming. Also, when i tried to take it apart, one of the screws was so firmly stuck, I damaged its hex hole and had to weld a hex thing in there to unscrew it...... Re: Renovating garden bench 3May 22, 2018 10:14 am Looks saveable, but it's a fair bit of work. Very fiddly work, even if you have the right tools. If I were doing this, and wanted to maintain timber finish, I'd want to own a really good detail sander, some tiny sanding heads for a dremmel tool, and a bunch of different grits of sandpaper from 80 to 240. One thing working in your favour is that it's not painted, and whatever protective finish it once had, looks to be mostly gone. If you're lucky, it was an oil finish, which means you're essentially working with raw material. More likely, there'll be bits of polyurethane film remaining, and you'll have to find a way to remove that. If you're going to paint it, then paint strippers are a shortcut, and you would only need to give it a light sand before prime coat, then final coat(s) of paint.
What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 8055 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 12436 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31732 |
