Browse Forums DIY, Home Maintenance & Repair 1 Dec 11, 2017 6:18 pm Hi all, I hope someone would be kind enough to help, Google didn't get me anywhere! I have a light fitting that looks like this; Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Which I need to attach to this plaster rose ornament; Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Can this even be done (with a screw plug or something)? it's obviously meant for a flat plaster ceiling and I've never drilled into plaster like that so not sure what it will do. Thanks for any help! Re: Screwing Into Plaster Ornament 5Dec 12, 2017 6:21 pm Yes, you wouldn't use that fake wooden base - the plaster rose takes the place of that. Your electrician should connect the cable to the mains in the same way the exisiting light is connected. Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5331 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5457 Our 6m high Cathedral ceiling has 0 insulation, just plaster, wrap and tiles as far as I can tell. Wife likes the exposed beams, I hate the $600 per month heating bill,… 0 13905 |
