Browse Forums DIY, Home Maintenance & Repair 1 Mar 15, 2017 8:01 pm Hi Wanting to mount a shelf on a wall that will need to hold about 35-40kg My home is a new home, timber frames. How much weight can the studs hold? for such a shelf i understand L shape brackets with a support brace would be required, and if the studs can handle the weight, what screws would you use? thanks Re: Wall stud weight? 2Mar 15, 2017 10:09 pm Hi buzurk Internal or external wall? Adjacent to a corner/intersecting wall or not? Is the wall restrained at the ceiling? Is your Roof built with trusses running perpendicular to the wall? more info required Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Wall stud weight? 4Mar 24, 2017 8:22 pm Shouldn't be an issue mate. Most big screen TV's weigh at least that much, so provided the item you are actually mounting to the wall stud is strong enough (ie the design of the shelf) then you shouldn't have an issue. The best method to attach something heavy to an internal stud wall is by using 'coach screws'. These are thick pointy tipped screws, but instead of having your typical flat head or philips screw top, they have a bolt head. You install them by drilling a pilot hole about 1/3 the size of the thread to the appopriate depth, and then socket them in like you would a normal nut until tight. Considerations: Avoiding services (water, electricity) in the wall. Finding the studs in the first place! Using the right amount of coach screws, and the right size and length. For instance, a flat panel TV has a mount with a large surface area. 4x coach screws (M10, 65mm) would sufficiently hold onto it no problem. When you are talking about a shelving system, you have to consider that because it protrudes away from the wall there's leverage (it'll try and pull itself away from the wall). So into a studs is the only way to go. Utilising an L shape bracket with support brace as you've said is the right way to go. Two or three coach screws into the wall on each bracket would certainly be enough to hang off it yourself (provided brackets were designed for the weight!). Pre-fabricated brackets typically have holes pre-drilled for you. Provided you find a bracket suited to the weight you require, just match the holes to the size of the coach screw, and buy enough to screw into wall using all holes available. If it's a partition wall leading to another room opposite side, dont get screws too long that they will protrude through the other side! I think 55-65mm would be plenty as you aren't talking about a lot of weight. Good luck! Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6280 ok thanks - yes was wondering if that should have been listed as Option Three! 2 8086 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4602 |
