Browse Forums DIY, Home Maintenance & Repair 1 Oct 13, 2014 8:20 am I'd like to put a timber screen in the carport to hide the bin area. The screen would be 2.9m long. Should I follow the slope of the driveway with the slats, or should I make the horizontal slats level and cut the bottom slat at an angle/step it? Also, should I use timber posts with stirrups or metal posts straight into the ground? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226276 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25581 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 2691 |
