Browse Forums DIY, Home Maintenance & Repair 1 Sep 14, 2010 10:43 am My house and verandah have separate corrugated iron roofs. The verandah was added later, and the sheets extend a short distance below the sheets of the roof. The overlap between these two levels is not sealed. The house roof is quite a steep pitch, while the verandah roof is reasonably flat. In the north queensland wet season, water travels up the verandah roof and leaks under the house roof iron onto the verandah below. We have a lot of trees overhanding our roof, and because of the flat pitch of the verandah roof, they sometimes come to rest just below the join, allowing water to bank up there and making the problem worse. I would like to seal the join between these two layers and stop this happening, but the fix is made more complicated by the fact that the curves of the corrugated iron on the house and verandah levels are not perfectly aligned, so the shape of the space between the two roofs varies, making the weatherproof foam and rubber inserts that are usually suitable for this purpose, unsuitable. I have considered using some kind of weatherproof tape but due to the misaligned corrugations, I am not sure that I would be able to make the tape curve as necessary and make a good seal. I have also considered some kind of waterproofing membrane treatment but I don't know much about them. Does anyone have any suggestions? Re: Water leaking where verandah joins the house 4Sep 20, 2010 10:03 pm Step 1: From inside the main roof space make sure the corrugate is úp-turned @60 degrees. Step 2: On the outside with a wire brush remove as much dirt and grime as possible dry the area with a heat gun (important to remove any moisture). Step 3: Silicone the external join...you're going to need heaps so don't skimp. (after the silicone has been applied you can spray soapy water over it to prevent silicone from sticking to your spreader) Step 4: After you've siliconed the external (when it's dry) silicone from the inside too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Water leaking where verandah joins the house 5Oct 24, 2010 9:03 am All of that but I'd prefer to hear Poly urethane used as silicone sealants breakdown/dry out/pull away. Where you are coming from is where you are going to... DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25064 Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 4261 1 3472 |
