Browse Forums DIY, Home Maintenance & Repair 1 Sep 14, 2010 10:52 am I have an Absco kit shed which was professionally erected on a concrete slab a couple of years ago. It fills up with water in heavy rain. The roof does not leak so as far as I can tell, the water is entering at the bottom where the steel panels meet the slab. The slab is a couple of inches above the ground level and the location drains well, so it seems that water running down the sides of the shed is somehow entering. I tried filling the little spaces between the wall panels and the metal track they sit in with expanda foam on one wall - messy and ineffective. I then tried siliconing around the inside of the shed where the metal track sits on the concrete - also ineffective. Any ideas? Re: Leaking garden shed 2Sep 14, 2010 12:46 pm It seems the water is running down the cladding into the bottom channel, filling it then overflowing inside. Have you tried drilling a few small drainage holes near the bottom of the channel on the outside? Inadequately silicone sealing where the channel meets the slab is usually where water enters. Arfur DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 25048 My first suspect area is at the bottom of the harvested downpipe furthest from the tank. PVC downpipes expand and contract with heat and cold, putting pressure on the… 3 2402 8 4111 |
