Browse Forums DIY, Home Maintenance & Repair 1 Feb 01, 2004 6:46 pm Before painting, ensure you have enough paint on hand to complete any given project.
Different batches of the same brand and colour may vary. A greater problem is when a paint dealer finds difficulty in matching custom paint colours. Remember, do you have enough paint? Re: Sufficient Paint! 3Sep 06, 2004 11:44 am When ordering paint ask the supplier to put the details on the paint lid. i.e. 'yellow ochere 7'
etc. etc. Often paint 'colours' are discontinued and having the original pigmentation details can prove to be invaluable. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Sufficient Paint! 4Sep 07, 2004 9:04 pm WHEN WORKING OUT COVERAGE OF STANDARD HOUSE PAINT I WORK ON:
INTERIOR BARE PLASTERBOARD 8-10 METERS SQUARE PER LITRE TOP COATS 14 -16 METERS SQUARE PER LITRE EXTERIOR BARE TIMBER 8-10 METERS SQUARE PER LITRE ON ROUGH SAWN TIMBER THIS COULD BE AS LOW AS 6 METERS SQUARE PER LITRE IT IS IDEAL NOT TO PAINT WHEN IT IS TO HOT, AND IS OK TOO ADD UP TO 10% OF OF THE RECOMMENDED THINNERS OR PAINT CONDITIONERS TO THE PAINT REF TO THE PAINT SUPPLIER DULUX 12 25 25 WATTYL 132 101 EXTERIOR FINISH COAT 14 METERS SQUARE PER LITRE EXTERIOR STAINS AND OILS ON BARE TIMBER 6 - 10 METERS SQUARE PER LITRE FIRST COAT AND THEN 10 - 12 SECOND COAT THESE ALSO VARY ON SURFACES YOU PAINT MAY IT BE BRICK, RENDER, HARDWOOD, SOFTWOOD, STEEL, PVC ETC. I HOPE THIS HELPS IF ALL ELSE FAILS GO INTO YOU LOCAL PAINT SHOP (NOT HARDWARE STORE MOST OF THEM KNOW SQUAT ABOUT PAINT) AND THEY SHOULD SET YOU ON THE RIGHT PATH ALL THE BEST EGGENZ 2004 paint....paint....paint 5Sep 19, 2004 11:38 pm Paint cans have their respective coverage on the tin. which is in sq mtrs, so a 3m x 3m wall would be 9 sq mtrs (one coat)
Paint can very a little, but not usually enough to notice. its always a gud idea not to start painting an area with a new tin when your halfway through the job. information on tin should contain.... name of color, whos colour (dulux etc), tint formula and preferbly date (this shuld be on bottom of cam...most people paint their lids and when u bring the can in they can see what paint, base etc. it was) Painting conditions are best on perfect days....you know nice temp nice breeze (if its too hot for you then its too hot to paint...if its too wndy well youknow, same goes for wet, cloudy, humid) Staff knowledge is trial and error unfortunately hardware shops usually have ex painters and or staff who have work for major paint companies like dulux etc but still every store will have someone you dont like or trust the trick is finding one It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows 3 20711 Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent. 4 6195 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 10164 |
