Browse Forums DIY, Home Maintenance & Repair 1 Apr 20, 2024 12:39 am Please suggest a correct way to fix this issue. I want to remove frog mouth and fix it properly because roots are getting through frog mouth and blocking pipes. I am thinking to connect 3 pipes to one 50mm pipe and connect one 50mm pipe to 100mm ORG.
3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at the same time. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Plumbing roots blocking PVC pipe 2Apr 20, 2024 8:37 am sudhir I want to remove frog mouth and fix it properly because roots are getting through frog mouth and blocking pipes. Frogmouth? It must surely be different to the failed Frogmouth filter previously manufactured by SilvanH2O. sudhir I am thinking to connect 3 pipes to one 50mm pipe and connect one 50mm pipe to 100mm ORG. What is at the top of the 3 pipes? Are the 3 pipes carrying grey and/or black water? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7416 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4999 I have a toilet that blocks up on the top (2nd) floor of a property. The toilets on the 1st and ground floor are OK) Blockage clears when the using a plunger. But… 0 621 |
