Browse Forums DIY, Home Maintenance & Repair 1 Apr 17, 2024 4:52 pm We bought the below mirror that we want to hang on the wall. Stud is not aligned to the position where we want to hang. https://amzn.asia/d/2X6VIC1 This the hooks provided. We can use some dry wall hooks with high weight rating. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Has anyone done this successfully? I got the below one from Bunnings, but the hook is bigger than the hole on the frame on the mirror. https://www.bunnings.com.au/zenith-40kg ... lsrc=aw.ds Any suggestions? Re: Hang 10kg mirror on dry wall. 2Apr 18, 2024 11:39 am firstly, this is sold to you as a floor mirror. Considder that for a moment. If you want to still hang it, there are lots of options for hanging stuff on drywall. But the simplest and best options i have seen for heavy objects is the 3M Claw. You could use some framing/hanging wire from one side to the other and hang the mirror via wire on a single central claw. You can get it from bunnings and there are lots of videos for it online. SImple, effective and minimal damage to the wall. Re: Hang 10kg mirror on dry wall. 3Apr 18, 2024 12:06 pm In Australia we call it plasterboard or gyprock - not 'drywall'. Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no… 0 1445 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9674 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6752 |
