Browse Forums DIY, Home Maintenance & Repair 1 Mar 12, 2024 10:14 pm Hi all I've got a brick garage/shed at the back of my house. It's been hit at some point (before I owned it) and has a large crack running down through the bricks. I want to salvage the shed as it's probably way cheaper than rebuilding. The shed also acts as a boundary fence, it's all fully approved from the 60s(?), isn't in the best shape, but overall seems fine. I will also replace the roof and roof structure if needed. It's a basic flat roof with only a few degree pitch with corrugated iron. I will also replace the current door with a roller door. I'd like some opinions on repair methods or what I should be looking at doing, professional or diy level etc. I was thinking some props on the timber lintel to hold this section of the roof up. Then I could demo out the damaged section. After that, just rebuild back to the lintel height. I was about to get a * quote, but I hate that website and haven't had good experiences. If people in Perth can recommend someone who might be able to assist, that would be cool. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Perth Hi, I'll be starting on my verandah repair soon - replace ledger, rafters, roofing iron, flashing etc. (fascia board already done). My question is about the timber ledger… 0 3411 DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 5280 DIY, Home Maintenance & Repair Hi All, Hoping someone might be be to provide some advice on my ceiling that needs repair. Photos attached, but seems like the alcove (??) is pulling away. Thanks Thomas 0 6630 |
