Browse Forums DIY, Home Maintenance & Repair 1 Mar 04, 2024 9:42 pm I need some advice regarding issues with the roof structure. I'm concerned about a crack in the hanging beam where it rests on the wall. It seems to be the only problem; the others appear to be fine. Do you think this crack is serious? Is it possible to repair it instead of replacing the entire beam? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ picture 1.1 crack in the hanging beam where it rests on the wall (overall view) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ picture 1.2 crack in the hanging beam where it rests on the wall (Partial enlargement of Figure 1.1, viewed from the front) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ picture 1.3 crack in the hanging beam where it rests on the wall (Partial enlargement of Figure 1.1, viewed from the side) Re: roof structure issues 2Mar 05, 2024 1:54 am A crack where the beam rests on the wall could potentially compromise the roof's integrity over time, especially under load or during severe weather. Repairing it might be possible, but it's essential to consult with a structural engineer or a qualified builder to assess the severity and recommend the best course of action. What I'm trying to say is that it looks as serious as cancer. Re: roof structure issues 3Mar 05, 2024 5:12 am Yes, need an engineer to inspect it. EmmaBarron3 A crack where the beam rests on the wall could potentially compromise the roof's integrity over time, especially under load or during severe weather. Repairing it might be possible, but it's essential to consult with a structural engineer or a qualified builder to assess the severity and recommend the best course of action. What I'm trying to say is that it looks as serious as cancer. Re: roof structure issues 5Mar 05, 2024 5:16 am Yes, because of the design, there is not much room for more bearing distance. Pulse it’s just a split from the two skew nails, no problem at all, ideally you should have more bearing distance but it’s not going to fail. Re: roof structure issues 6Mar 05, 2024 10:17 am Does anyone have an idea of how much it might cost to replace this roof strut beam? It won't be a straightforward job; we might need engineer drawings and a building permit. Re: roof structure issues 7Mar 10, 2024 9:23 am not a huge problem, just contact a local roofing company or engineer and see what they say Re: roof structure issues 8Mar 10, 2024 9:45 am homediyguy not a huge problem, just contact a local roofing company or engineer and see what they say Thanks for the advice, will get an structural engineer to inspect. There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 7092 Shade the brick with large eves. Since going to minimum of 600mm eaves on my build, I've noticed much improved cooling off the house after hot summer days. Can see the… 1 4716 Hi everyone I have a terracotta tiles roof When I climb inside the roof cavity I can feel that there is a draft inside the roof as the wind goes through the roof which is… 0 4957 |
