Browse Forums DIY, Home Maintenance & Repair 1 Oct 12, 2023 2:37 pm My fencing contractor could not supply the gate motor I needed, so I plan to get a suitable one and install it myself (low voltage 2-core wire setup, external transformer, sliding gate). I am pretty handy with my tools and it doesn't look very difficult, but would be interested to hear from anyone who has done this before. Thanks, regards Chris Re: DIY fence gate motor installation? Easy? 2Oct 15, 2023 5:51 am Hello, There's not a whole lot to them, 4 bolts into concrete and then screw your rack to the gate with a touch of clearance so the rack doesn't have pressure on the gear. The electrical side I would not like to give advice on but if you're just plugging it in then it's an easy enough job if your fence has been built properly and they've laid down concrete where your motor goes (preferably after You've run conduits to your motor Re: DIY fence gate motor installation? Easy? 3Oct 15, 2023 6:02 pm Hi, Thanks for your reply. Yes it doesn't look very complicated, just wanted to check if someone has done it. I have been quoted $1'000 to $1'400 bucks for installation (without the motor). Thought it was a bit of a rip off. Regards Re: DIY fence gate motor installation? Easy? 4Oct 15, 2023 6:14 pm ChrisBirmele Hi, Thanks for your reply. Yes it doesn't look very complicated, just wanted to check if someone has done it. I have been quoted $1'000 to $1'400 bucks for installation (without the motor). Thought it was a bit of a rip off. Regards I mean, I install them/sell them for a living so I haven't done DIY, unless you count the first one I installed lol. (electrician by trade). Usually a 6-8 hour job for my techs to install , wire up and install gate rack, so at electrician rates $1000 isn't too far off the money to be honest. I guess it's the electrical part that would put most off. Some control boards require you to bridge out safety inputs and other little things that you would need a basic understanding of electrical circuits to get up and running. My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 2834 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12251 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9256 |
