There is a blockage in this S Bend pipe. Do I have to have an S Bend here, and what’s the best way to fix it?
Thanks.
Browse Forums DIY, Home Maintenance & Repair Re: External Tap S Bend Blockage 2Sep 16, 2023 9:20 pm Few questions, how did you pick up the blockage, and what was the blockage. That's an overflow gully and you need it so if you get a blockage between your house and the main it doesn't back up into your house. You need the s part to stop the stink. Re: External Tap S Bend Blockage 3Sep 16, 2023 9:34 pm Ardo Few questions, how did you pick up the blockage, and what was the blockage. That's an overflow gully and you need it so if you get a blockage between your house and the main it doesn't back up into your house. You need the s part to stop the stink. Picked up the blockage because it overflows out the top of the pipe at ground level. It’s still blocked. I’m only assuming it’s at the S bend. Re: External Tap S Bend Blockage 5Sep 17, 2023 9:16 am SamMac .....what’s the best way to fix it? Call a plumber. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: External Tap S Bend Blockage 7Sep 18, 2023 12:13 pm I haven't seen him for a while. What did you do with him? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: External Tap S Bend Blockage 8Sep 18, 2023 2:47 pm SaveH2O I haven't seen him for a while. What did you do with him? hes probably been banned. Hopefully it was something more ironic like a girder fell on his head despite having BIM and getting 3 quotes. 1 4198 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7913 Brass or 2) Stainless steel made - which Kitchen tap is good for drinking.Brass kitchen taps in Australia contain lead… 0 7030 |
