Hi
I'm planning to build a kitchen island with MGP10 untreated 70x35. Would this be a good idea? Is MGP10 structural prone to warping usually?
Thanks
Browse Forums DIY, Home Maintenance & Repair Re: MGP10 pine for a bench 2Aug 07, 2023 7:24 pm kate_r Hi I'm planning to build a kitchen island with MGP10 untreated 70x35. Would this be a good idea? Is MGP10 structural prone to warping usually? Thanks Hi Kate Do you mean the benchtops or the entire island unit, frame and all? Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: MGP10 pine for a bench 3Aug 07, 2023 7:30 pm chippy kate_r Hi I'm planning to build a kitchen island with MGP10 untreated 70x35. Would this be a good idea? Is MGP10 structural prone to warping usually? Thanks Hi Kate Do you mean the benchtops or the entire island unit, frame and all? Hi chippy, I was thinking to use MGP10 just for the frame. A friend is giving me a piece of benchtop off cut. I wonder if 70x35 will be enough for the 4 legs. Re: MGP10 pine for a bench 4Aug 07, 2023 7:48 pm Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or similar in the corners and then your framing material can be smaller. MGP10 is usually a construction grade timber. You can get clear pine (no knots or gum) or other hardwoods that are probably a little bit nicer for furniture building. 70x35 is also probably a bit lightweight. Depending on how you are building it, whether you are using some form of jointing or just relying on glue and fixings you may need a bit more dimensionally. Look online for a set of plans. There's plenty available that will give you an idea what sizes are required. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52974 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 13117 DIY, Home Maintenance & Repair Hi, I have an old fence/barrier made of treated pine logs bolted to plates and these are bolted to very large metal posts/girders. The plates and bolts are rusted through… 0 16486 |
