Browse Forums DIY, Home Maintenance & Repair 1 Jul 10, 2023 9:05 pm Hi all, First post here with minimal knowledge in anything building related. We moved into our home not long ago. When I was looking at the subfloor the other day I uncovered one of the brick piers is starting to bow a bit. The front of the house has been replaced with acrow prop at some stage (I suspect there may have been movement at some stage). Where they've put one of the bearers is off centre on the brick pier which appears to be the reason it's bowing. Is this normal practice? Is it cause for concern? We did a building inspection, as did the previous owners and neither reported on it. Side note - the floor roughly above the pier or thereabouts seems a bit raised when inside the house. In addition to the above there is moisture around the acrow props sections which is obvious and was picked up in the reports, so we need to look into where it's coming from. For both the above, who would be best to engage? And does the pier need to be assessed in the first place, or is slight movement like that ok? Plumber, structural engineer, builder??? Any insight and recommendations would be greatly appreciated! Rob Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brick pier starting to bow and moisture issue 2Jul 11, 2023 10:23 pm Th acrows are just steel posts where it was restumped, the bricks were layed like that, the off centre bearer is not a big issue just sloppy building, just sort out the moisture, watch the brick pier, if the floor is uneven the replace the brick piers with more steel ones Re: Brick pier starting to bow and moisture issue 3Jul 13, 2023 9:58 pm Pulse Th acrows are just steel posts where it was restumped, the bricks were layed like that, the off centre bearer is not a big issue just sloppy building, just sort out the moisture, watch the brick pier, if the floor is uneven the replace the brick piers with more steel ones Thanks for that! Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7451 these look like missing batts. Go up and take a look. But yeah moisure meter is a completely different tool 4 9638 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8406 |
