Browse Forums DIY, Home Maintenance & Repair 1 Jul 12, 2023 11:34 am Hi all. The backside of my old brick shed has about 1m of soil up against it. As a result, every wet season when the soil becomes sodden, the water seeps through the bricks and the shed floods. I have started to dig a trench next to the brickwork as shown in the pic. My question is about what to do next. I was thinking a waterproof membrane against the brickwork and then some gravel/ag pipe to get the water away? Any advice appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Soil against brick shed 2Jul 12, 2023 1:46 pm I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing it off. Paint the wall with bitumen waterproof paint right down and onto the footings. Give it at least 2 good coats making sure you get into the mortar joints. I'd then line the wall with corflute from the footing up to the soil level to give you another layer of moisture resistance. Make sure you overlap the joins and tape them. Then lay your agi pipe on a layer of gravel up against the corflute making sure to connect up to your stormwater and back fill with more gravel. Not sure if there is any extra steps required (that would be more than adequate in WA) but that should provide a decent level of moisture resistance and will last Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 DIY, Home Maintenance & Repair Hi all I've got a brick garage/shed at the back of my house. It's been hit at some point (before I owned it) and has a large crack running down through the bricks. I want… 0 9224 6 4423 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4953 |
