Browse Forums DIY, Home Maintenance & Repair 1 Jul 12, 2023 11:34 am Hi all. The backside of my old brick shed has about 1m of soil up against it. As a result, every wet season when the soil becomes sodden, the water seeps through the bricks and the shed floods. I have started to dig a trench next to the brickwork as shown in the pic. My question is about what to do next. I was thinking a waterproof membrane against the brickwork and then some gravel/ag pipe to get the water away? Any advice appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Soil against brick shed 2Jul 12, 2023 1:46 pm I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing it off. Paint the wall with bitumen waterproof paint right down and onto the footings. Give it at least 2 good coats making sure you get into the mortar joints. I'd then line the wall with corflute from the footing up to the soil level to give you another layer of moisture resistance. Make sure you overlap the joins and tape them. Then lay your agi pipe on a layer of gravel up against the corflute making sure to connect up to your stormwater and back fill with more gravel. Not sure if there is any extra steps required (that would be more than adequate in WA) but that should provide a decent level of moisture resistance and will last Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 DIY, Home Maintenance & Repair Turning this into my DIY shed makeover. I had a brickie fix the back wall up and it's rock solid now. I'm into ripping down the inside ceiling that was installed and… 1 11260 6 4576 Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is… 3 1363 |
