Browse Forums DIY, Home Maintenance & Repair 1 Jun 01, 2023 9:22 pm I have recently purchased an old home built in the mid to late 50's on brick piers. All the piers have a slight rearward lean to them, when I place a spirit level which is 800mm in length the piers are out from between 25 and 40mm. With the exception of one all appear to be in good order and bearers are sitting firmly with no floor squeak or movement. The pier movement I believe is the result of water constantly sitting around piers which I intend to rectify. My Question to the forum: Should I be concerned about the lean on the piers and do I need to rectify or can it be left as I have no way of knowing how long it has been in its current state. Re: Leaning House piers 2Jun 03, 2023 11:35 am If all the piers lean rearward it may mean you house has slid horizontally rearward, it's worth competent inspection. You are right about drainage issues. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaning House piers 3Jun 03, 2023 12:01 pm building-expert If all the piers lean rearward it may mean you house has slid horizontally rearward, it's worth competent inspection. You are right about drainage issues. Is there an acceptable level of movement where the cause can be rectified and the existing movement left as is and just monitored? Re: Leaning House piers 4Jun 03, 2023 4:09 pm You will need expert opinion but if your house has moved it then is a structural issue and the cause must be determined and then the method of remedy. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaning House piers 6Jun 04, 2023 11:21 pm building-expert If all the piers lean rearward it may mean you house has slid horizontally rearward, it's worth competent inspection. You are right about drainage issues. Hi Building expert, Would like to know your thoughts about the "uneven flooring" in upstair laminated floor ? The handover inspection reported that the floor measured over greater 10mm flooring in 2 m length in most bedrooms. I am waiting for the builder's investigation and their actions to get it fixed. The handover is waiting since Apr this year. What do you suggest I should do at this moment ? Re: Leaning House piers 7Jun 05, 2023 9:54 am ceciyau building-expert If all the piers lean rearward it may mean you house has slid horizontally rearward, it's worth competent inspection. You are right about drainage issues. Hi Building expert, Would like to know your thoughts about the "uneven flooring" in upstair laminated floor ? The handover inspection reported that the floor measured over greater 10mm flooring in 2 m length in most bedrooms. I am waiting for the builder's investigation and their actions to get it fixed. The handover is waiting since Apr this year. What do you suggest I should do at this moment ? Your handover report should include findings, expert opinion and recommendations. If so follow recommendations, if not then get a competent Pre handover report. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaning House piers 8Jun 05, 2023 10:34 am building-expert ceciyau building-expert If all the piers lean rearward it may mean you house has slid horizontally rearward, it's worth competent inspection. You are right about drainage issues. Hi Building expert, Would like to know your thoughts about the "uneven flooring" in upstair laminated floor ? The handover inspection reported that the floor measured over greater 10mm flooring in 2 m length in most bedrooms. I am waiting for the builder's investigation and their actions to get it fixed. The handover is waiting since Apr this year. What do you suggest I should do at this moment ? Your handover report should include findings, expert opinion and recommendations. If so follow recommendations, if not then get a competent Pre handover report. I have received the report with the defects found, there was “a rectification required “ in each defect, no solution suggested. I understand you are not in Sydney region, so do you recommend me to conduct another handover inspection ? Any recommended inspector? It has been two weeks since the report received and sent to the builder, haven’t heard from the builder what to resolve the issue, OC has not received. The build has been lasting for 3 years from the day I signed to tender in 2020 including 6 months pause due to my health issue and a year of DA approval, Covid and lack of timber…. Now finally reached the handover stage, but still extremely slow in handling all issues. Should I seek for legal advice and mediation for speed up process ? Re: Leaning House piers 9Jun 05, 2023 1:32 pm ceciyau building-expert ceciyau Hi Building expert, Would like to know your thoughts about the "uneven flooring" in upstair laminated floor ? The handover inspection reported that the floor measured over greater 10mm flooring in 2 m length in most bedrooms. I am waiting for the builder's investigation and their actions to get it fixed. The handover is waiting since Apr this year. What do you suggest I should do at this moment ? Your handover report should include findings, expert opinion and recommendations. If so follow recommendations, if not then get a competent Pre handover report. I have received the report with the defects found, there was “a rectification required “ in each defect, no solution suggested. I understand you are not in Sydney region, so do you recommend me to conduct another handover inspection ? Any recommended inspector? It has been two weeks since the report received and sent to the builder, haven’t heard from the builder what to resolve the issue, OC has not received. The build has been lasting for 3 years from the day I signed to tender in 2020 including 6 months pause due to my health issue and a year of DA approval, Covid and lack of timber…. Now finally reached the handover stage, but still extremely slow in handling all issues. Should I seek for legal advice and mediation for speed up process ? Re: Leaning House piers 10Jun 05, 2023 1:50 pm Kippers01 ceciyau building-expert Your handover report should include findings, expert opinion and recommendations. If so follow recommendations, if not then get a competent Pre handover report. I have received the report with the defects found, there was “a rectification required “ in each defect, no solution suggested. I understand you are not in Sydney region, so do you recommend me to conduct another handover inspection ? Any recommended inspector? It has been two weeks since the report received and sent to the builder, haven’t heard from the builder what to resolve the issue, OC has not received. The build has been lasting for 3 years from the day I signed to tender in 2020 including 6 months pause due to my health issue and a year of DA approval, Covid and lack of timber…. Now finally reached the handover stage, but still extremely slow in handling all issues. Should I seek for legal advice and mediation for speed up process ? Hi Kippers01 Thanks for your advices. I am still waiting…for builder’s investigation, if no news received within this week. I will be finding another building inspector to conduct detail investigation on ceilings, walls and every floor. Any suggestions of what type of building inspector I should be hire ? Any good referrals? Re: Leaning House piers 11Jun 06, 2023 9:17 pm You will need more than a building inspector, a building consultant, someone with extensive building experience, contract administration and who can produce and give exper evidence in NCAT. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaning House piers 12Jun 07, 2023 8:42 am building-expert You will need more than a building inspector, a building consultant, someone with extensive building experience, contract administration and who can produce and give exper evidence in NCAT. That’s very helpful information. Will find out more from there. Much appreciated. 3 2111 I am building a new residential house. The structural engineer suggests drilling 60 bored piers which are no less than 600mm deep and at lest 300mm in stiff clay. If… 0 857 Hi, I have a block that I am planning on building on soon to both side boundaries, which both have other houses constructed that were also built boundary to… 0 531 |
