Browse Forums DIY, Home Maintenance & Repair Re: Outdoor rendering for the first time 21Oct 29, 2015 10:46 am Just no greater than about a cm at a time. Re: Outdoor rendering for the first time 22Nov 01, 2015 2:35 pm Put the stop bead on the other day, then got some more basecoat on today. I'm having to do some thick layering to build up these couple of patches - does the levelling process get easier when you do the thinner layer at the end? Pretty hard getting a perfect finish when you have to cake it on... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 9542 Soak wells and electrical run in happening this week! Summit has told me they will relocate the laundry plumbing after the walls are completed. I'm actually pretty happy… 13 36857 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5464 |
