Browse Forums DIY, Home Maintenance & Repair Re: Brick Repointing 5Dec 22, 2006 7:46 pm If your getting a brickie in, its good time to put in some extra vents if needed too. Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21351 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8885 |
