Browse Forums DIY, Home Maintenance & Repair 1 Jun 11, 2017 4:49 pm I'm wondering if anyone can give me any tips on how to understand if my garage sectional door unit is level. It has the motor mounted to the ceiling, which follows rails that hold the door at the ceiling height, and which travel towards the front of the sectional door. It's generally noisy even though I had it serviced around 6 months ago. Any help would be appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How to know if Garage Sectional Door is level? 2Jun 11, 2017 5:02 pm In my experience, they are always noisy to a degree, but it depends on whether you think the noise is different from when it was first installed, and exactly what is making that noise. As far as I can tell, the only necessary level is across the door, which yours seems to be because it lines up with your bricks (unless your brickie did a bad job). I'm not quite sure why you are measuring the level of the motor? Re: How to know if Garage Sectional Door is level? 3Jun 11, 2017 6:54 pm Thanks for replying so quickly! I though that the top bar would have to be stable as it drags the door all the way up. Is there a way that I can measure all the way around somehow to see if it's square and the right distance from the bricks and ceiling, or should I just leave it? isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 18321 Move your linen into laundry and access laundry from your present linen space 1 8503 Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 7409 |
