Browse Forums DIY, Home Maintenance & Repair 1 Nov 26, 2016 6:52 pm Hi, I have a lot of these small round holes on the second floor of my double story house, there aren't any on the ground floor. I remember seeing them many years ago but for some reason dismissed it, however recently many more have started to appear. They usually appear in rows. I've attached photos of them. http://imgur.com/a/C0mkP I think they come from the ceiling starting to sag and the nail stayed in place causing the part of the ceiling connected to the nail to separate from the main ceiling. I tried pushing up on the ceiling and it fixes the hole. Is there a proper name for this and is there a way to fix it? Do i need to call a professional and if i do who would i call? Also saw some sort of crack on the ceiling as well, is this related to the holes? Additionally the vents of my central heating are falling down, how can i fix this as well? Re: Little holes on ceiling and falling heating vents 2Dec 06, 2016 4:38 pm Yes this ceiling and these holes may be related to each other and you need to call a professional. You can find any professional for this type of work on local search engine and you can call who is near about you. Re: Little holes on ceiling and falling heating vents 3Dec 07, 2016 9:12 am ok thanks, i'll go contact my original builder. Shade the brick with large eves. Since going to minimum of 600mm eaves on my build, I've noticed much improved cooling off the house after hot summer days. Can see the… 1 4727 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 16907 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11961 |
