Browse Forums DIY, Home Maintenance & Repair 1 Aug 01, 2016 11:52 am Hi there, I have a part of my polished concrete seal peeling off (I put some double sided tape on it to make sure a rug stayed in position, when I removed the tap the seal came off too!). It's about the size of a 50cent coin, here's a picture: What is the best way to fix this? I have the following timber floor seal from a job I did last year, do you think I can use this rather than buying something new? Thanks for your help! Re: Polished Concrete Peeling Off - How To Fix? 4Aug 02, 2016 1:31 pm No, I'd find out what product the concrete floor polishers used and buy that instead of introducing something different to the mix. It could give you a completely different finish otherwise. Stewie DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6671 DIY, Home Maintenance & Repair If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?. 3 6171 |
