Browse Forums Outdoor Living 1 Apr 29, 2020 10:59 pm Hi there, I am currently getting a deck built and am wondering if I should do something to the dirt around footings to stop water pooling? There is a AG drain running straight through middle of deck but wondering about footings further away. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Footings for deck 2May 01, 2020 8:49 pm It would probably be better if the ground surface below the deck was graded (only slightly) so all water is shed and transferred away to the edges and then away Could you raise level of the footings to that of the soil then grade the surface with a little wacker plate so it ends up lower than the top of the footings? I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5988 So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23381 Hi, does anyone have any experience with using Trex rain escape or EPDM rubber to waterproof a deck so you have dry space underneath. Popular in the US and realize that… 0 3727 |
