Browse Forums Outdoor Living 1 Apr 21, 2020 4:10 pm For the under construction house, Alfresco is about 2.2m wide and 5.5m long. Pic attached. There are 3 Brick Peirs on the longer sude blocking the view from Family and also making the Alfresco looks very narrow. What can we do about it? Is it worth tearing these piers down to put Metal pillars? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alfresco - Brick piers 2May 01, 2020 3:28 pm You could remove the centre pier and replace the beam/lintel with a larger unit that has the specification to span the entire opening. IMO, metal posts would look like a cheap add on/afterthought and not match the intended style. 3 3037 I am building a new residential house. The structural engineer suggests drilling 60 bored piers which are no less than 600mm deep and at lest 300mm in stiff clay. If… 0 1160 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4549 |
