Browse Forums Outdoor Living 1 Sep 25, 2019 4:31 pm Hi everyone, I would appreciate some assistance regarding the following. I have had an insulated pergola installed recently. Electrical wiring and cutouts for downlights have been done. I have been advised by the electrician that unlike normal gyprock ceilings which have sufficient gaps for a plug base to be connected to the wiring, in this case, due to lack of space he will have to hardwire it to the downlight. Is this right? In addition, he mentioned that the fan installation might not be suitable for such insulated ceilings due to the weight of the fan. Is there a maximum weight these versiclad panels can take and has anyone installed fans on such ceilings? Thank you in advance. Re: Downlights and Fan for Versiclad Insulated pergola 2Nov 18, 2019 9:59 am We have downlights in our insulated roof and they hardwire them in (cut off the standard power cord) as the have the transformer in the back of the light. We also have a fan without an issues, just make sure he doesn't fix straight to the bottom of the ceiling and instead runs threaded rod all the way through with a large washer/plate on the top Good questions but the best answer will be obtained by visiting (ie: interviewing) a couple of house designers and/or builders and ask them. You may find it challenging to… 2 3570 My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5522 Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1934 |
