Browse Forums Outdoor Living 1 Nov 03, 2017 2:20 pm We've had to install a stormwater pit with a granny flat build. Unfortunately it's located right next to our alfresco. I've noticed that it's full of water and that we've had an increase in the number of mozzies since its install - they're bl***y huge Can anything be done about the stagnant water/mozzie situation ? Any solutions ? Thanks everyone Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Stormwater pits and mozzies 2Nov 03, 2017 8:57 pm You could put a little concrete in the bottom of the pit to raise it flush with outlet pipe, that way you will avoid pit holding water however the pit won't function as a silt /rubbish trap. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Stormwater pits and mozzies 3Nov 04, 2017 6:42 am the outlet pipe is quite high in the pit would need to put in a lot of concrete to raise the bottom which would then negate the purpose of the pit could I pour something down there regularly to minimize the numbers of mozzies???? Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Stormwater pits and mozzies 4Nov 04, 2017 4:00 pm try innocco oil, it is claimed to be pesticide free, however you cannot use anything that may cause fuel vapours and cause potential explosion risk Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Stormwater pits and mozzies 6Nov 26, 2017 11:42 pm If you can lift the grate off the top of the pit (it should be removable) then wrap some mozzie screen round it (put it on the underside of the grate so it does not get torn by anyone walking on the pit cover) and pop it back in then the mozzies should be denied access to the water. Re: Stormwater pits and mozzies 8Nov 27, 2017 10:25 am Yes, that will work for a short time but the mesh may block really quickly with probability of SW pit overflow and other damage Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 9041 Can you post your Architectural and Hydraulic plans so we can see how the system as a whole works? Without that no one will be able to give you any meaningful… 2 1197 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 5633 |
