Browse Forums Outdoor Living 1 Nov 02, 2015 4:06 pm G'day all, great forum and first post. I am currently planning an outdoor kitchen on a new deck I have built. I would like to DIY most/all of the kitchen but I have been reading conflicting reports regarding materials. I have read that you cannot have combustible materials within 430mm of the BBQ. Is this 430mm negated if you insulate around the BBQ/heat source. i.e. a metal or cement sheet type material under and around the BBQ. I would ideally like to use treated pine for the frame but if the 430mm still stands I'm not sure what I will use. I'm not sure what I will do for the bench top. I wanted to use timber again but I think that will be out. Maybe might just use blue board with tiles over the top. Thanks. Mick That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8796 You need to reference the manufactures installation guide, your supplier may have strengthened the base where it is not required to sit on a bed. 1 1998 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 8051 |
